541,063 active members*
3,383 visitors online*
Results 1 to 5 of 5
    May 2020
    14
    Current Step jog function buttons
    Hello everyone,
    I know the menu options are viewable on button bars. I abuse it a bit but I stall on one option.
    I would like to know if it is possible to create buttons related to the current Step of the Jog function? This option can be selected by right clicking on the Jog panel.
    I tried some solutions like Jog.Jog_Current_Step but without success.
    I would like to display 3 buttons corresponding to the options 0.01 - 0.1 and 1 mm. The option chosen would obviously be highlighted.
    Another solution would also be to have this type of button directly in the jog function panel.
    Best regards
    Moderator
    Mar 2017
    806
    Re: Current Step jog function buttons
    Easiest way is with expressions. Put this in your btn file
    expr: "_jog_step=0.1" "J0.1" ""
    expr: "_jog_step=1" "J1" ""
    expr: "_jog_step=10" "J10" ""
    May 2020
    14
    I'm back,
    By searching a little, I found the solution. Using the _jog_step parameter
    Here is the extract of the commands to put in the file corresponds to the desired button bar:
    expr: "_jog_step=0.01" "Jog 0.01" imagechange="True" stroke=1.1 color=#ffffff updown="_jog_step==0.01" updatefast="true" tooltip="Jog current step = 0.01 mm"
    expr: "_jog_step=0.1" "Jog 0.1" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.1" updatefast="true" tooltip="Jog current step = 0.1 mm"
    expr: "_jog_step=1" "Jog 1" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==1" updatefast="true" tooltip="Jog current step = 1 mm"
    You can see the result below.
    I still have to define an image for each of these buttons to have a nicer rendering.
    Hope this can help some of you.
    May 2020
    14
    Hello,
    I see that our posts are crossed.
    To end this post, here is the final result with icons.
    I even tested 1µ steps, but it doesn't work. on the other hand, the NC works perfectly from 5µ steps.
    I nevertheless observe a 1µ offset when I take several consecutive steps, probably related to my management of steps per mm of my motors.
    Another advantage of these buttons is that you can directly see the setting of the steps because the button is highlighted.
    As the default option is 0.1mm, the 0.1 button is directly selected when starting TNG.
    Extract from the btn file:
    expr: "_jog_step=0.005" "" image="Icons/IMG_JogStep0.005_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.005" updatefast="true" tooltip="Jog current step = 0.005 mm"
    expr: "_jog_step=0.01" "" image="Icons/IMG_JogStep0.01_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.01" updatefast="true" tooltip="Jog current step = 0.01 mm"
    expr: "_jog_step=0.05" "" image="Icons/IMG_JogStep0.05_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.05" updatefast="true" tooltip="Jog current step = 0.05 mm"
    expr: "_jog_step=0.1" "" image="Icons/IMG_JogStep0.1_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.1" updatefast="true" tooltip="Jog current step = 0.1 mm"
    expr: "_jog_step=0.5" "" image="Icons/IMG_JogStep0.5_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==0.5" updatefast="true" tooltip="Jog current step = 0.5 mm"
    expr: "_jog_step=1" "" image="Icons/IMG_JogStep1_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==1" updatefast="true" tooltip="Jog current step = 1 mm"
    expr: "_jog_step=5" "" image="Icons/IMG_JogStep5_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==5" updatefast="true" tooltip="Jog current step = 5 mm"
    expr: "_jog_step=10" "" image="Icons/IMG_JogStep10_White.png" imagechange="True" stroke=1 color=#ffffff updown="_jog_step==10" updatefast="true" tooltip="Jog current step = 10 mm"
    Best regards
    Moderator
    Mar 2017
    806
    Nice
  1. External Jog Buttons
    By sean69_uk in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-13-2021, 04:38 PM
  2. jog buttons for mach 3
    By speedtwin69 in forum Taig Mills / Lathes
    Last Post: 06-25-2016, 03:33 PM
  3. input wiring jog buttons how to
    By marty37 in forum Controller Cards
    Last Post: 09-07-2015, 05:03 PM
  4. Interfacing 3 Position Rotary Switch with Cycle Jog Step Function
    By MRM RCModels in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2010, 01:34 PM
  5. Jog buttons occasionally stick, runaway gantry
    By Brian Queen in forum Mach Mill
    Last Post: 08-30-2007, 11:35 PM
