591,380 active members*
7,138 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Current Tool Variable # Fanuc 31i Model B
Results 1 to 10 of 10
    Jul 2021
    6
    I’m trying to find the variable that holds the number for the current tool that’s called up for a Macro. It’s on a Doosan Puma with 31i control.
    I have seen similar posts on here suggesting #4120 but that just contains 0.
    Aug 2007
    833
    Quote Originally Posted by jedd View Post
    Upload your macro or entire backup here
    Dec 2012
    398
    Re: Current Tool Variable # Fanuc 31i Model B
    Check your Tool Change Macro.
    Probably stored in #100, in my macro it is; #100 = #4120, Toolnumber is shown in #100.
    Regards.
    Aug 2007
    833
    Quote Originally Posted by Heavy_Metal View Post
    Regards.
    If #4120=0 then
    #100=#4120=0
    #100 - local temporary variable
    #4120 - global system variable
    Dec 2012
    398
    Mr guhl,
    Were did I say #4120 = 0 and #100 = 0 ???
    When I do a toolchange like T9 M6 varaible #100 shows 9 after toolchange, depending on the toolnumber !!!!
    My ( HWacheon Vesta 1000 ) macro says: #100 = #4120 and stores the 9 in #100, simple as that.
    O9020(M06 T..AUTO CHANGE)
    G31
    #148=#4003
    IF[#1014EQ1]GOTO10
    IF[#20EQ#0]GOTO10
    IF[#20EQ0]GOTO902
    #100=#20
    GOTO20
    N10#100=#4120
    N20
    M606T#100
    G49
    G#148
    M99
    N902#3000=2(M06 TF-CODE COMMAND ERROR)
    M30
    Aug 2007
    833
    Mr guhl,
    G31
    #148=#4003
    IF[#1014EQ1]GOTO10
    IF[#20EQ#0]GOTO10
    IF[#20EQ0]GOTO902
    #100=#20
    GOTO20
    N10#100=#4120
    N20
    M606T#100
    G49
    G#148
    M99
    M30
    You wrote
    #100=#4120
    Hence, if #4120=0 (like author claimed), then we can say that #100 will be equal 0 as well
    #4120=0 and #100=4120 -> #100=0
    Author will see in #100 the same like in #4120
    Feb 2013
    22
    jedd,
    #4120 is a system variable that you can not see. If, like Heavy_Metal said, you go into your tool change program and right after the M6 add #100=#4120.
    Then when you look in your macro variables page you will see your tool number in 100.
    Just a note, you can use any common variable you choose (#100 to #199) it does not have to be just #100
    Jul 2021
    6
    Thanks for the replies. I was looking through SYSTEM>PARAMETERS thinking it was reading from there.
    Is there no way of browsing through the system variables or can I find a list anywhere of other system variables?
    Dec 2012
    398
    There are plenty of variable lists, just Google for it.
    https://www.cnccookbook.com/fanuc-ma...d-programming/
    https://www.machinetoolhelp.com/Appl...variables.html
    and many more.
    Aug 2024
    On a Doosan Puma with a 31i control, the variable that holds the current tool number for a macro is typically #5000
    papa's scooperia
  1. System variable for the current tool length
    By kheston in forum Tormach PathPilot™
    Last Post: 03-07-2018, 04:37 PM
  2. Variable out of range Fanuc 31i
    By markkirby in forum G-Code Programing
    Last Post: 10-15-2010, 02:50 PM
  3. fanuc 31i - model A5
    By anilam in forum Fanuc
    Last Post: 02-15-2010, 02:22 PM
  4. Current tool # variable
    By hydrospin01 in forum Fanuc
    Last Post: 07-15-2008, 07:32 PM
  5. Macro variable for current tool diam ?
    By Shizzlemah in forum Fadal
    Last Post: 10-30-2006, 03:47 PM
