555,184 active members*
1,734 visitors online*
Results 1 to 4 of 4
    Curving Text in Maestro
    Anyone out there drawing in Maestro active CNC version ever draw text in a curve or arched shape? Or know how to do it in that program? I can get text on the plane but cant shape it anyway but straight. Help would be appreciated.
    Jun 2015
    3647
    Re: Curving Text in Maestro
    hy i can help you with a custom app, that will deliver g-code for text on a curve / kindly
    Feb 2007
    390
    Hello,
    Sorry I can't help with Maestro but Dolphin PartMaster CAM can produce text around an arc, ellipse or any shape.
    ATB
    Andre
    Jan 2022
    6
    I do not know much about Maestro active CNC version. Give Dolphin PartMaster CAM a try. You can produce text around an ellipse, arc, circle, or in any other shape using Dolphin PartMaster CAM. It is not much complicated to use. If you have been using other CAM software then you can produce text around curves or arched shapes quite easily using Dolphin PartMaster CAM, even if you have never used it before. There are some videos on youtube that can help you in case you do not figure out how to draw the text. And if you have to do it in Maestro active, then hopefully some being can help you or try reading the documentation.
  1. 4-axis CNC machine RC1325RH working on curving surface
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 09-20-2019, 01:58 AM
  2. Curving between corners
    By justinj in forum LinuxCNC (formerly EMC2)
    Last Post: 09-28-2018, 03:34 PM
  3. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  4. V21 Curving text
    By FISHERTECH in forum BobCad-Cam
    Last Post: 03-04-2011, 03:02 PM
  5. Letters,Numbers and inserting and curving text
    By piedpipertraps in forum DynaTorch
    Last Post: 06-26-2008, 10:51 PM
