567,245 active members*
4,227 visitors online*
Results 1 to 1 of 1
    Dec 2017
    3
    Cutter comp/ manual guide i
    When I do a radius using g42 and manual guide I, They come out a 1/64 over what they are programed to. Nose radius is set to correct nose radius. Curious if there is a parameter I should look into. Or is there something I'm overlooking.
    Flies Fast
    Dec 2008
    2968
    Re: Cutter comp/ manual guide i
    Lathe or mill ?
    Inside or outside contour ?
    Post the NC file.
