547,049 active members*
2,595 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Cutter Compensation
    Cutter Compensation
    When I post my code out of Edgecam 2011, the lead move to turn cutter compensation on is posted on the line after the G41 line. Same with the G40 line. Is there a way to get the lead move to show up on the same line as the G41/G40 instead of the next line?
    Thanks,
    Keith
    Jun 2015
    3441
    Re: Cutter Compensation
    hy, if you can't fix that, i can create a simple program that will shift the rad comp code at the previous/next/whatever block
    checking to be an inposition, feed, and before it, only rapid movements allowed and whatever else condition you wish ?!
  1. Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    By Stavros Flatly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2013, 02:48 AM
  2. Cutter Compensation D ?
    By Chappyd in forum G-Code Programing
    Last Post: 12-16-2012, 12:32 PM
  3. cutter compensation
    By gotyernumber in forum Fanuc
    Last Post: 09-29-2011, 03:46 PM
  4. Cutter Compensation
    By Terry G in forum Taig Mills / Lathes
    Last Post: 01-29-2011, 05:44 AM
  5. cutter compensation
    By seven3 in forum UG NX
    Last Post: 01-27-2011, 08:55 PM
