On my cnc control panel I have 8 push buttons and created the ID tags for them in my printer and glued them as needed. I want now to engrave these tags on some plastic material I have and I'm against a wall...
Each tag should be about 1" long by 1/2" height and the font a plain Arial font with a height of 3/16". I will use a 1/16" ball endmill with a max depth of cut 1/8"
I first tried the Engraving from the Toolpaths menu but never used that before and decided to stop.
Then I thought a plain Contour path maybe the solution. I used the Create/Letters menu to make my first tag "system" all in small letters. Then in the Contour Toolpath I set my parameters and at the end I get "Cutter compensation not Successful" and MCx5 after gets locked - have to restart the PC. Did it twice with different compensation and the same results
Any idea why this happens and perhaps a suggested solution?
