549,879 active members*
2,382 visitors online*
    Sep 2010
    Lightbulb Cutting Oil or Coolant
    We have a great condition but old shaper and hobber machines (Barber Colman). Currently we are running small- 10" to large 20" ring gears of carbon steel. The machines have always run on cutting oil but we are trying to decide if it would be possible to switch over successfully to an emulsion type coolant or fully synthetic. We have tried the idea successfully on cast iron parts and would like to see if there is anyone out there that has made this switch or know of someone who has on hardened steel. Thanks in advance!
    Dec 2021
    Re: Cutting Oil or Coolant
    China fresh garlic also has antibacterial, antifungal and antiviral properties so it has more numbers of health benefits. Medical research says that is helping to normalize the lipoprotein levels and it is supporting the cholesterol levels. It is used for treating the respiratory and bronchitis problems.
  1. Replies: 0
    Last Post: 01-26-2010, 02:53 AM
  2. Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-29-2009, 09:37 PM
  3. Coolant or No Coolant when turning....
    By Crashmaster in forum General MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  4. Cutting fiberglass, what coolant?
    By SteveD in forum Community Club House
    Last Post: 10-23-2006, 02:42 PM
  5. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 07:09 PM
