591,467 active members*
8,094 visitors online*
    CW-5200 not cooling
    Good evening all!
    Just a short question in case anyone else has faced the same problem,
    Chiller powers up and looks fine, however it doesn’t cool down the water at all! Once turned on the water slowly heats up.
    I’ve tried a few test pieces with the ambient temp been around 24, the water temp climbs up to mid 30’s and sets off the E2
    Any help would be greatly appreciated!
    Many thanks Jacko
    Quote Originally Posted by Jackson4911 View Post
    Good evening all!
    Many thanks Jacko
    I'm having this same issue, did you ever find an answer. Was working fine for first couple weeks, now it won't get cool enough, and it heats up super fast. Although the copper pipes feel cool to the touch, the compressor gets pretty hot though
    Jul 2024
    Re: CW-5200 not cooling
    Hi, did you get anywhere with this issue? I have exactly the same problem. The compressor feels like it's running and gets hot. The controller appears to be working as it should.
  1. LMS 5200 mini lathe spindle wobbling
    By dimbmw in forum Mini Lathe
    Last Post: 12-18-2017, 05:11 PM
  2. s&a cw-5200 chiller
    By curious in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-29-2014, 10:55 AM
  3. Replies: 0
    Last Post: 06-02-2014, 07:24 PM
  4. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 09:02 PM
