548,466 active members*
2,522 visitors online*
Thread: Cw230 driver
    Cw230 driver
    Which breakout board would be compatible with the Cw230 controller?
    Jan 2018
    1026
    Re: Cw230 driver
    Quote Originally Posted by servoman1 View Post
    You mean one of these?
    https://www.rcscomponents.kiev.ua/da...-datasheet.pdf
    Any breakout board which can deliver a 5v pulse & direction signal.
    So I assume you're on a budget?. If you can get a pc with parallel port and 32 bit win7 or xp then:
    Most are or better setup to be wired common anode as per page4 fig2 in the driver manual above.
    Such as:
    https://www.aliexpress.com/i/33042193580.html
    https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
    I used one of these for a few years and was great.
    There are many boards that can be wired either way so be careful with your wiring and double check everything as you go.
    Such as:
    https://www.automationtechnologiesin...breakout-board
    For controlling via usb if you have no parallel port I would NOT touch the NVEM based units such as:
    https://www.amazon.co.uk/Motion-Cont.../dp/B07L4QVQCB
    These are the most common boards used in basic chinese hobby machines when using usb:
    https://www.aliexpress.com/item/1005...912f169576e347
    If wanting to use a laptop (or aanything win10 based) to run it then go with an ethernet controller such as the UC400eth (if using Mach or uccnc).
    Attach the 5 axis board at top of list to it using an idc26 to db25 cable (or both top baords using both ports for more IO)
    For an all in one ethernet based system I'd recommend an AXBB-E.
  1. Replies: 4
    Last Post: 08-01-2019, 08:25 PM
  2. Help with EMC2 timing for CW230 drivers?
    By kazoochips in forum LinuxCNC (formerly EMC2)
    Last Post: 05-24-2012, 03:11 AM
  3. CW230 Driver board Help
    By crodriguez1517 in forum Stepper Motors / Drives
    Last Post: 04-12-2012, 12:25 AM
  4. need help with CW230 driver timing for EMC2
    By kazoochips in forum Stepper Motors / Drives
    Last Post: 01-11-2012, 08:48 PM
  5. MicroStep CW230
    By achavarria in forum Controller & Computer Solutions
    Last Post: 11-01-2009, 03:36 PM
