508,083 active members
3,710 visitors online
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo MYNX-500 spindle encoder belt
Results 1 to 7 of 7
    Oct 2006
    6
    Post Daewoo MYNX-500 spindle encoder belt
    I have the spindel's encoder belt broken and I need to disassemble the upper part of the spindle in order tu put the new belt in place.
    I have only the general parts drawings includes in the user manual. I need more detailed drawings of spindle assembly before to start the job.
    Is anyone could provide me such detail and also some advises?
    It would be greatfull!
    The CNC is a MYNX-500, SN: AV5E 0414
    Thank you in advance!
    Oct 2006
    6
    Re: Daewoo MYNX-500 spindle encoder belt
    Part of solution has been found in the following post:
    https://www.cnczone.com/forums/daewo...-machines.html
    Let me re-post two docs found on it:
    Oct 2006
    6
    If you have any advice it's welcome !
    Jul 2005
    326
    For this type of issue, contact Darryl Hardt in service. 973-618-2461
    Oct 2006
    6
    Thanks Douglas!
    Feb 2013
    595
    You literally have the best document for the best information, linked in the post that you did at 0741 today...
    Doosan Service Technician
    darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
    Oct 2006
    6
    Hi Darryl, thank you for your confirmation.
    Let's start the job ;o)
  1. Daewoo Mynx 500 parameters help
    By netomx in forum Daewoo/Doosan
    Last Post: 03-11-2019, 05:36 PM
  2. Daewoo ACE-V35 OMC spindle drive belt
    By ElZoido in forum Daewoo/Doosan
    Last Post: 11-25-2013, 07:15 PM
  3. atc daewoo mynx 530
    By pierrot-mtl in forum Daewoo/Doosan
    Last Post: 04-16-2013, 06:07 PM
  4. Daewoo 4020 Mill Spindle Belt Breaking
    By Mark18969 in forum Daewoo/Doosan
    Last Post: 09-16-2009, 05:06 PM
  5. spindle encoder belt
    By RICKG in forum Fanuc
    Last Post: 10-23-2007, 12:14 AM
