548,591 active members*
2,748 visitors online*
Results 1 to 4 of 4
    Mar 2004
    1508
    DC servo vibrates at rest
    I have a CNC mill with DC brushed servos controlled by an 1880 Galil card...
    It is an old machine that has worked well for a great many years. I recently moved it 2000 miles. Just powered it up today. The Y axis will vibrate at the stop position. Move it and it may be fine or it may vibrate again. Put your hand on the servo and its rotating back and forth rapidly just a half degree or so.
    What should i do to correct this?
    Karl
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23797
    Re: DC servo vibrates at rest
    Usually with Galil that has torque mode drives, it is in the PID tuning parameters.
    i.e. too much gain.
    Albert E.
    Mar 2004
    1508
    These ran fine for more than a decade. Just re tune???
    I was guessing the move shook something loose or broke?
    Dec 2013
    5182
    Retuning is what I would do also. Try bumping up the KD parameter, makes it react just a bit slower without affecting the stiffness much. I guess the other possibility could be encoder noise, loose connection? Maybe look at the raw encoder data to see how stable it is..
    Jim Dawson
    Sandy, Oregon, USA
  1. torch vibrates when moving slow
    By cruz03 in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-30-2018, 07:00 PM
  2. BOB has DIR,STP,GND,ENA driver has CP+,CP-,CW+,CW-,Rest-, Rest+.
    By bayouburner in forum General CNC Machine Related Electronics
    Last Post: 06-15-2017, 03:27 PM
  3. Replies: 14
    Last Post: 11-21-2016, 10:08 AM
  4. DC Servo Vibrates on Fanuc 6M
    By parametric.ms in forum Fanuc
    Last Post: 03-25-2011, 03:58 PM
  5. Motor just stalls and vibrates!
    By prcdslnc13 in forum Stepper Motors / Drives
    Last Post: 12-02-2010, 01:58 PM
