535,183 active members*
3,777 visitors online*
Thread: Debug Lead
Results 1 to 4 of 4
    Jun 2013
    198
    Debug Lead
    I'm using Stepperonlines CL57T that are made by Leadshine (written on the side). They look exactly like the HBS86H.
    Quick question about the debug software. More pointedly the lead. I can't remember what I used to connect last time. I have two leads. A USB to RJ11 and a Serial (db9?) to RJ11.
    I can't get a connection on either of them and can't remember which one worked. Obviously the USB would be best just not sure if it was the one.
    Any help?
    Sent from my SM-N970F using Tapatalk
    Nov 2012
    1013
    Re: Debug Lead
    According to the manual, the RJ11 connector in the CL57T is a serial RS232 port. If your computer does not have a serial port (most likely), you can use the USB to RJ11 adapter. Make sure you have the drivers for it properly installed and the COM port number properly set in your software.
    Jun 2013
    198
    Re: Debug Lead
    Cool thanks. I'm kicking myself not remembering how I did it last time. I try to connect it up now to my XP computer and nothing shows up in device manager or the tuning program. I am not even sure if the copy of XP has the drivers.
    If there is anything I know relatively nothing about it is ports and coms in computers. I am hoping if I get a USB converter that maybe a pc with windows 10 will just pick it up...... (hoping). To add, I actually don't like this bit of cnc. The rest is very cool indeed
    Nov 2012
    1013
    Re: Debug Lead
    Your adapter will show in the Device Manager as either a COM port (if the drivers are installed) or as an unknown device (if the drivers are not installed yet).
    If it shows as an unknown device, look at its hardware IDs to figure out what kind of drivers it needs. No need to buy another USB converter if you already have one that worked before.
  1. Compost3 Debug DLL
    By cncrunner in forum GibbsCAM
    Last Post: 06-18-2015, 08:17 PM
  2. Debug CNC Loop
    By LGentry in forum G-Code Programing
    Last Post: 01-22-2013, 03:51 AM
  3. Debug mode
    By Pipe in forum Mikron / Haas
    Last Post: 07-02-2011, 04:43 PM
  4. Debug
    By Fido57 in forum Haas Mills
    Last Post: 02-24-2008, 02:15 PM
  5. Help needed to Debug G41 G42 problem
    By Al_The_Man in forum Uncategorised CAM Discussion
    Last Post: 07-06-2004, 12:22 AM
