549,877 active members*
2,128 visitors online*
Results 1 to 5 of 5
    Dec 2021
    3
    Deckel 64V with fanuc 180i
    Hello everybody!
    I have an issue with my cnc machine. When i turn on the power supply i can't start imediatly my job because apears an alarma that say:
    "1038 ENERGY RECOVERY ,MODULE NOT READY"
    How i can fix that?
    Thanks a lot!
    Aug 2019
    86
    Re: Deckel 64V with fanuc 180i
    The alarm shown is generated in the PLC (ladder) as indicated by the alarm number (1000 series). It will not be found in any Fanuc manuals. You will need to check the OEM documentation or look in the ladder for the cause.
    Its possible someone in the forum has this machine and my be able to help.
    Dec 2021
    3
    Thanks for you help oetkbyentc! I'll check machine manual.
    Dec 2021
    3
    Does anyone have the same problem? I've seen the machine manual but I haven't found anything. To start my work, I have to wait a long time to reset the alarm, and i don't have way to connect me to the PLC. Thanks a lot!
    Aug 2019
    86
    We can hope the OEM has used simple logic for the machine.
    To start
    Check to see that the OEM has the ladder set to be displayed.
    If they do
    Go to the PMC status screen.
    Look for "A0".
    Start scrolling down looking for an "A" address that is high ( a 1).
    When you get through the area go to the ladder.
    Search (W SRCH) for that "A" address' that were high.
    Hopefully they have used symbols make sense to the alarm you are seeing.
    Check the logic to see what is triggering the fault.
  1. DMC 64V Linear Fanuc 180i Spindle wont Initailize!
    By streetsidetools in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-21-2017, 10:10 PM
  2. Deckel Maho Model DMC-104V lineat with Fanuc 180i-MB
    By Big_Nasty in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-23-2014, 09:07 PM
  3. M-code for deckel maho 64V linear with Fanuc 16iMB controller
    By hartan in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-22-2013, 10:35 PM
  4. Replies: 10
    Last Post: 03-02-2013, 05:00 AM
  5. post processor fanuc 18i mb5 and fanuc 180i Ma
    By nickargas in forum PTC Pro/Manufacture
    Last Post: 02-27-2013, 11:54 AM
