589,390 active members*
7,431 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Deep CNC Milling - At least 3-1/2" LOC end mill bits?
Results 1 to 1 of 1
    Apr 2012
    15
    Hello,
    I'm hoping others can share their solutions or tooling choices when trying to do at least 3-1/2" length of cuts for end mill bits. We very commonly need to route out parts from 3-1/2" to 3-1/4" thick lumber. We are struggling finding affordable solutions to achieve this length of cut.
    We can use tooling up to 1" diameter but certainly prefer 1/2" diameter bits. Best we've been able to find is 3" LOC. Which is also a fairly standard Freud bit.
    Best we've found is this 3" single flute off Amazon. But just not deep enough.
    https://www.amazon.com/dp/B07CTVZR7G...WxfdGhlbWF0aWM
    Apr 2004
    5770
    Re: Deep CNC Milling - At least 3-1/2" LOC end mill bits?
    Here's one I found without too much searching. Not cheap, though...
    https://allindustrial.com/kyocera-sg...uare-end-mill/
    Andrew Werby
    Website
    Dec 2013
    5722
    Jim Dawson
    Sandy, Oregon, USA
