540,760 active members*
6,990 visitors online*
    Jun 2019
    7
    Deep mill part Tooling Questions
    2 Questions.
    We have the Tormach 440 and I have a deep part that is 2.25 tall with a center bore. We have the long-reach arbor TTS tool holders with the 25mm mill head.
    The question is can I use this tool for my finishing passes? Surface quality is not a huge factor for this application but we still want a nice-looking part. The cylinder that makes up the bore ID and OD is not a dimensional aspect of the part function.
    Deep drilling, same depth I need to make 4 .25 holes in this part all the way through. Holes will be drilled after facing, then will cur the bore.
    Should I go with a carbide drill bit for this? or will standard tin coated jobber bit be fine?
    Should I do a pilot hole all the way threw
    Attached Thumbnails Attached Thumbnails Coys parts V5 Change to Inch (2213 KB) - Rhinoceros 5.0 Commercial - [Perspective] 2021-03-17 11.jpg   31817 - TTS M12 Threaded Arbor_ Medium _ Tormach - Google Chrome 2021-03-17 11.06.52.jpg   31258 - Center Cut End Mill - 25 mm _ Tormach - Google Chrome 2021-03-17 11.06.19.jpg   31754 - Carbide Insert for Aluminum and Plastic - Center Cut End Mill 25 mm 10-Pack _ Tormach - .jpg
    Apr 2016
    107
    Re: Deep mill part Tooling Questions
    Yes your arbor tool seems like one of the better options to get it done. Low axial depth of cut and fairly high feed. Should keep your part accurate with no taper even if surface finish isn't ultra good.
    I'm just thinking out loud here but rather than trying to drill all the way through 2.25" of material with a 1/4" drill on a 440 (that's pretty deep at 9x drill diameter)... maybe go ahead and machine the bore with your extended arbor and then plunge mill the remaining portion of the feature with a long reach 1/4" end mill. No chance of the drill getting overloaded that way and it looks like well less than 50% stepover from the pic there so maybe a good option to do in just one plunge. Lots of axial rigidity and plenty of chip clearance. You have 10" of travel on the Z axis so should be enough room?
    Jun 2019
    7
    Thanks, Good thought on the plunge milling opp VS drilling. I guess in Fusion that would just be a modified drilling opp, correct? I spoke to Tormach tech support and he told me the 440 would do fine drilling this hole but I still question it as well.
  1. Cutter drives deep into part
    By schesby in forum PlanetCNC
    Last Post: 08-12-2020, 06:39 PM
  2. Small deep cavties and Shrink Tooling
    By AsterMachining in forum Tormach Personal CNC Mill
    Last Post: 03-21-2017, 07:40 PM
  3. Large Deep Bore on a Casting: Tooling/machine
    By brad47 in forum CNC Tooling
    Last Post: 11-06-2015, 01:58 PM
  4. TTS compatible tooling for 2-3" deep pocketing ops?
    By digits in forum Tormach Personal CNC Mill
    Last Post: 06-06-2012, 09:15 PM
  5. deep part off w/peck help
    By theatrewizard in forum Haas Lathes
    Last Post: 12-04-2008, 03:47 PM
