527,819 active members*
2,449 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Denford Triac fanuc O-M Datum problem
    Aug 2013
    4
    Hello
    I bought a Denford Triac milling machine on Fanuc O-M and after a short time I noticed that the axes could not be homed. Manual axes movement works ok, no alarms are displayed when I try to homing the axes. I made a backup of the parameters parameters. In the attachment I added copies of parameters and diagnostics, maybe someone will notice a problem why I can't datum the axes . Best regards
    Apr 2011
    623
    Re: Denford Triac fanuc O-M Datum problem
    Try powering down the control then press and hold the P and CAN buttons while it powers up. Make sure that you jog the axis away from the home position on all the axis before trying to home.
    Aug 2013
    4
    hi
    Unfortunately I tried it already.
  1. Denford Triac Fanuc OM ATC Fault
    By jamesgates1000 in forum Benchtop Machines
    Last Post: 12-13-2017, 03:23 PM
  2. DENFORD TRIAC VMC
    By haasmanuk in forum Benchtop Machines
    Last Post: 10-06-2014, 03:43 PM
  3. Replies: 0
    Last Post: 04-21-2011, 07:57 PM
  4. Denford triac help
    By Jimthefish in forum Stepper Motors / Drives
    Last Post: 03-30-2010, 11:11 AM
  5. Posthaste file for Denford triac fanuc OM-C wanted
    By ANGAENGINEERING in forum Post Processor Files
    Last Post: 08-08-2009, 12:18 PM
