537,582 active members*
3,424 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Desperately Need VFD help!
    Feb 2021
    I am new to using a CNC. I have a CNCEST 6040, 4 axis, 1.5kw spindle. I reprogrammed the VFD values. Now the spindle will spin, but it is not moving on any of the axis. It doesn't matter if I'm using manual or computer. As I said I am new to this, Any and all help is appreciated.
    Community Moderator
    Dec 2003
    23630
    Re: Desperately Need VFD help!
    What motion (CNC) system is it running?
    How is it programmed G.M. code etc?
    You should be able to move the axis regardless of the spindle via a MDI move.
    Al.
    Albert E.
    Gold Member
    Apr 2004
    5245
    Does it move if the spindle and VFD are turned off?
    Andrew Werby
    Website
  1. Desperately need help with Sinumerik 3T
    By Smokio in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2013, 03:59 PM
  2. New to WaterJet and desperately need help!
    By Danimal25 in forum General Waterjet
    Last Post: 01-05-2011, 12:38 AM
  3. desperately need help
    By rusty abe in forum Linear and Rotary Motion
    Last Post: 06-30-2010, 02:54 AM
  4. Mitsubishi 110 G Need Some Help Desperately
    By worldsworstfish in forum General EDM Discussion
    Last Post: 05-05-2010, 10:06 PM
