525,432 active members*
2,503 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > diagram of mitutoyo linear scale model AT112-one side is 9 pins?
Results 1 to 4 of 4
    Registered SparkyNL's Avatar
    Nov 2016
    14
    does anyone have a diagram of Mitutoyo linear scale model AT112 using a 9 pins round plug?
    I need to match it to a KS series DRO that uses a 15 pin RS232 type connector
    It is very difficult to find àny information on these connectors: it would be a great great help if I would know the +5V Vss and the color of the Ground wires because the other two signals can be determined using an osciloscope
    The connector has the following colors:
    red
    orange
    yellow
    blue
    green
    brown
    Normally the +5V is red and the grnd black but there is only a brown colored wire
    again any help is greatly appriciated
    thanks!
    Nov 2016
    14
    Re: diagram of mitutoyo linear scale model AT112-one side is 9 pins?
    sorry it is not a 9 but a 8 pin connector like this :
    Jun 2005
    1381
    Look for the manual for their reader it will list the pins and signal names
    Russ
    Jun 2007
    12
    Quote Originally Posted by SparkyNL View Post
    Did you ever figure this out?
  1. Mitutoyo AT116 linear scale
    By braco in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2017, 03:47 PM
  2. mitutoyo linear scale pinout
    By pham1129 in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2017, 03:44 PM
  3. mitutoyo scale a11-n wires pulled
    By speedchaser in forum General CNC Machine Related Electronics
    Last Post: 10-30-2012, 02:34 PM
  4. Sargon DRO & Mitutoyo AT715-750 Scale
    By ynnek in forum General CNC Machine Related Electronics
    Last Post: 08-02-2009, 04:30 PM
  5. mitutoyo linear scale cable pinout
    By pham1129 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2008, 02:25 PM
