585,698 active members*
3,490 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Disc milling at a high depth
    Hello everyone, I need to make a kind of throat at a very high depth with a mazak integrex e-670h using a hsk100 anti-vibration attachment 350 long from the big kaiser, 2 extensions of 100 and an anti-vibration extension of 180 big kaiser in diameter 63, I mount a hss disc cutter with a chipbreaker profile with a diameter of 100 thickness 6, a total exit of 800, the throat is 30 thick 15 deep in a hole with a diameter of 180 material 20mncr5 (iron), I have problems with bending of the 'tool that makes the cutter last a short time, I would like to know if anyone has ever done something like this and has something to advise me, I tried to look at the angle heads to totally change the method but there are none with such a leak, I hope to having explained myself and not having left anything out. hello and good luck.
    Jun 2015
    4154
    Re: Disc milling at a high depth
    hy can you share images with tool, part & fixture ?
  1. Milling depth control
    By rhys79 in forum CNC Tooling
    Last Post: 12-15-2012, 05:23 PM
  2. What depth to use for milling?
    By psychoul in forum PCB milling
    Last Post: 09-20-2011, 09:39 AM
  3. Alesa - disc milling cutter
    By 5-Achser in forum CNC Tooling
    Last Post: 08-05-2009, 11:04 AM
  4. Maximum CNC milling depth
    By Dr. DRE in forum MetalWork Discussion
    Last Post: 12-17-2006, 05:39 AM
