562,490 active members*
3,700 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > DIY mpg handwheel for USB mach3 board
Results 1 to 1 of 1
    Aug 2014
    I need some help here; I'm making my own MPG pendant. I'm using this 80mm mpg handwheel and this USB mach3 board. I know the wiring is correct, ports & pins configurated as you can see in the attached images, input #1, input #2, input #3, input #4 checked, encoder 1, MPG#1 checked.
    Looking at the diagnostics window I know I have signal in the input 3 and input 4, but looking at the settings info window, MPG diagnostics, nothing moves.
    Any idea about what I'm doing wrong.
    Attached Thumbnails Attached Thumbnails mach3 image3.jpg   mach3 image4.jpg   mach3 image5.jpg   mach3 image1.jpg
