Can anyone confirms me DM3000 Z travel disltance, is it 11inch?
THX,
THX,
With or with out tailstock ? What type of chuck , center, collet chuck are you going to use ?
Hi Gabedrummin,
Below is my DM3000, it would be great to know both the distances with Tailstock and without.
Can those information be found in the Dynamyte 3000 Manual 1 and 2 or Service manual?
It will travel to the right until the carriage hit's the limit on the back side of the bed . It will travel z- till it crashes into the chuck if you don't stop it . So the limit switch on the back is adjustable so you can adjust the home position .The length of z travel is between those two points.
MY machine has about 8 inches of z with the tail stock on and about 12 with it off .
