541,079 active members*
3,035 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
Results 1 to 5 of 5
    Question DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
    Hello,
    I am Kerim, a bachelor student that is trying to acquire data from a CNC machine of which the model is DMG Mori DMU75 Monoblock. We are currently working on a project which needs current (electricity) data of servo motors of the CNC. However, we do not know how to transfer this data on a PC environment. Is there anyone who knows how to transfer current data (in terms of Amperes) to a PC? Thank you already for anyone's effort.
    Dec 2013
    4802
    Re: DMG Mori DMU75 Monoblock Current Monitoring (Need Help)
    The best way to do this is using non-invasive current transformers. There are all kinds of devices available, Google 'power monitoring' . Here is one way to do it, maybe a good starting point. https://learn.openenergymonitor.org/...energy-monitor
    Jim Dawson
    Sandy, Oregon, USA
    Thank you very much for you help! After building this circuit, where can I put this device to monitor the current? Thanks in advance.
    Dec 2013
    4802
    You would run the motor power wires through the current transformers.
    There also may be a way to read the individual drive current directly from the drives using the ModBus or whatever protocol that system uses, you would need to look at the drive documentation for more information.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2002
    1616
    Which controller is used with your machine?
  1. DMG 85 mori monoblock Cycle 800 + Traori
    By sparticles in forum Mori Seiki Mills
    Last Post: 08-12-2017, 02:34 AM
  2. DMG 85 Mori monoblock probe alarm when doing manual measure
    Last Post: 08-10-2017, 06:24 AM
  3. DMG MORI
    By robwiacek in forum Musical Instrument Design and Construction
    Last Post: 04-01-2015, 01:29 AM
  4. Mori and DMG
    By underthetire in forum Mori Seiki Mills
    Last Post: 02-05-2012, 10:29 PM
  5. mach 3 monitoring current draw
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 04-15-2009, 04:00 AM
