so, some time I bought 2001 okuma mb46 u100m or osp7000, it has low memory so after some thinking I have decided that I need dnc-b option for it, it's quite an expensive option so I decided to install it with help of some forum members, bought needed cards, got the software, installed everything, sorted the cabling, sorted control panel, machine receives data, but does not run a program from dnc, my question is like is it possible that I'm missing some parameters? when I press cycle start I instantly get 3218 alarm, dnc start condition 1, I have read the manuals and so on, this error appears if DSR signal is not coming in the machine, but as seen in pictures it's coming there, anyway what's interesting that in page 51 which shows dnc-b status I have 0 in all parameters, not sure does that have to be that way or I'm missing some data here. Any input would help me, thanks.
1. Parameters which cannot be Set at OSP
The parameters indicated below cannot be set at the OSP and setting is possible only by using the SET
command from the host computer.
(Parameters in the table below, conversion codes, codes after conversion (45th - 48th bytes of SET
command))
(For protocol A only)
4188-E C-17
http://douglasrudd.com/manuals/Okuma...20Function.pdf
