585,954 active members*
4,061 visitors online*
Results 1 to 6 of 6
    Jul 2012
    28
    DNC Mode on Fanuc O-M Controller
    Hi
    I have a cnc MAX REBEL 1 with control Fanuc O-M.
    How to activate DNC mode? The selector panel options are: Edit, auto, MDI, Handle, Teach in Handle, Teach in Jog , Jog and Zero Return.
    if I select auto mode and send these are stored in memory, live not run.
    thanks
    Dec 2003
    24221
    Depends on the version, but usually the option selector switch is installed by the OEM, as the PMC ladder requires the BMI register G127.5 set on by the switch.
    Al.
    Albert E.
    Jul 2012
    28
    Is version C.
    concerning the register G127.5, is a parameter change or modified hardware?
    Thanks for reply
    Dec 2003
    24221
    The G registers are ones that the PMC send to the CNC side, F registers are from CNC to PMC.
    So it requires a run to be written into the ladder and a switch fitted normally.
    Al.
    Albert E.
    Jul 2012
    28
    Hi
    worked in this way:
    In mode MDI run M51 code and press cycle start
    after in mode AUTO press again cycle start
    on screen display LSK.
    Ready for send from PC.
    Sep 2021
    3
    Re: DNC Mode on Fanuc O-M Controller
    Hello
    I have a Kitamura Mycenter 1 with a Fanuc OM controller. The parameters were erased by mistake on the controller. I obtained a copy of the parameters from the manufacture and have re-entered them. Upon power up I do not get any alarms on the CRT but I do get "not ready" in the lower left corner. I also get "THND" on the CRT in the position normally displaying "MDI", "EDIT" etc. Any help would be appreciated.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Replies: 1
    Last Post: 06-25-2010, 04:13 AM
  3. SX3 spindle speed controller (CNC Mode)
    By iGG1e in forum Syil Products
    Last Post: 10-31-2008, 05:32 PM
  4. Replies: 4
    Last Post: 09-08-2008, 03:50 PM
  5. Phase mode without controller
    By Alex101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2007, 11:53 AM
