543,675 active members*
2,217 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > DNC problem with milltronics centurion 6
    Nov 2015
    23
    Hello
    we can RS232 load programs through cimco into memory no problem.
    when we try to dnc larger programs. the mill will run for a while , then watching the verify the tool path will go past what appears to be the buffer.
    Its almost as the control cannot take more information and the program errors out.
    looking at the screen error 501 illegal address. the block only has a few numbers, it has the y value but x is missing
    is this a control problem or a cable problem
    any help will be greatly appreciated
    Gord
    Aug 2009
    973
    Re: DNC problem with milltronics centurion 6
    ...most likely the cable if, randomly crashes in DNC.
    #1 causes are USB to Serial converters and/or unshielded RS232 cables.
  1. Milltronics ml 15 by 40 centurion 7 control
    By aspeyrer in forum Milltronics
    Last Post: 01-18-2021, 08:03 PM
  2. Problem with a Milltronics VKM3 Centurion 6
    By WrenK in forum Milltronics
    Last Post: 10-12-2017, 12:16 AM
  3. Replies: 5
    Last Post: 06-08-2016, 12:13 AM
  4. Milltronics Centurion IV DNC?
    By papp101 in forum Milltronics
    Last Post: 01-04-2014, 03:57 AM
  5. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
