547,049 active members*
2,462 visitors online*
    Dec 2012
    8
    Exclamation Does anyone have a H4ldr.uc file?
    I lost User Init in my Multicam 1000
    I accidentally wrote down the parameters of the machine in "User Init"
    Because they are similar in format "cts"
    Now I need "H4ldr.uc" to write it down in "User Init" NVRAM
    Just in case I will write the parameters of the machine:
    ****Router Machine S/N M2400****
    Loader V6.70
    Standard V6.70
    MCIF V4.41a
    uCITO V2.06c
    Keypad KDM20 V1.20
    Controller :
    LC520 Rev 2 Interface M64 (ID 22)
    Serial Num #2400
    Speed 133MHz
    Memory 8M
    Step Delay ON
    IP Address 192.168.0.88(255.255.240.0)
    Bus Voltage 36.178 VDC
    Module Information
    MODULE INI_STD 2 6.70
    MODULE INI_MD4 20 1.28
    MODULE INI_INIT -3 6.70
    MODULE INI_INVERTER 5 2.19
    MODULE INI_SELFTEST 1 0.00
    FIRMWARE 4.41a
    SERIAL_NUM 2400
    FEATURES 199485
    MEMORY 3
    MPU_MHZ 133
    CONTROLLER_REV 2
    CONTROLLER LC520
    Dec 2012
    8
    Re: Does anyone have a H4ldr.uc file?
    I found the original parameters file.
    And I received the "User Init H4ldr.uc" file from the Multicam service center in Russia
    The machine is repaired, everything works!
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Windows x64 text file splitter that goes by lines, not file size?
    By Galane in forum Uncategorised CAM Discussion
    Last Post: 04-06-2015, 12:26 AM
  3. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  4. using a data file for both 3D printer and CNC router , Converting file or ???
    Last Post: 12-17-2014, 01:32 AM
