585,962 active members*
4,147 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Does anyone use the Tormach 440 for 1018 cold rolled steel?
Results 1 to 5 of 5
    I’m buying a 440 but can find too many specs on people using it for 1018 CR. I make small parts from .75” x .50” stock and want to know if it can handle a DOC of .25 with a WOC of .375 using a 3/8x2" .020" 4FL 1/2" F/L *AlCrN* end mill from Garr tooling. Thanks in advance
    https://www.garrtool.com/search-results/?search=50494&material=&tool=&inch=Inch&fluteDiame ter=&numFlutes=&cornerRadius=&fluteLength=&reachLe ngth=&overallLength=&coating=#
    Re: Does anyone use the Tormach 440 for 1018 cold rolled steel?
    Sorry not .375 WOC but .075 WOC
    Mar 2020
    218
    Is there a specific reason for that particular tool and those specific cut parameters? I know the 440 will handle 1018 because I've done it (makerspace machine) and that was back when I had NO clue what I was doing. I don't know that it has the power to handle that big of a cut though. I suppose it will depend a bit on your chip load.
    Jun 2014
    1780
    My opinion from what I have read over the last few years, I would go with the 770 as it has a much better rapor than the 440.
    I have an 1100 s3 and it is a bit underpowered as well when using larger cutters.
    mike sr
    Nov 2013
    402
    .075 radial might be too much load on the 440's motor.
    It might stall.
    I would do more passes, with a lighter radial load. Maybe .015 per pass.
  1. cold rolled steel for rails
    By 3Dsigns in forum Linear and Rotary Motion
    Last Post: 02-26-2013, 10:24 PM
  2. Cold rolled steel, flats or square for use as rails.
    By Apples in forum Linear and Rotary Motion
    Last Post: 06-26-2012, 03:51 PM
  3. Flat Ground vs. Cold Rolled Steel?
    By piperpilot in forum DIY CNC Router Table Machines
    Last Post: 12-02-2011, 07:21 PM
  4. Cold Rolled Steel Uk sourcing?
    By rbs in forum DIY CNC Router Table Machines
    Last Post: 08-14-2010, 11:55 AM
  5. Cold Rolled Steel Accuracy
    By Zach_G in forum Mechanical Calculations/Engineering Design
    Last Post: 11-26-2008, 03:59 AM
