Noobie, first post.
That being said I think I have gotten pretty far.
Instructable DIY Plasma table.
Using SheetCAM and Mach3.
Problem:
Pretty simple drawing, Sheet cam shows the cut lines with arc in and arc out.
When running the gcode it goes to cut a small bolt hole it looks like a C. The torch completes the movement but the torch turns off before the end of the cut.
It does this on all of the cut. I found a post of similar issue and said it was Spindle CW spindown delay. I have tried setting them to 0. I have tried immediate shutoff.
Suggestions?
I will try to upload all of my setting and photo.
Thanks in advanced for any advice.
Cheers
