550,143 active members*
3,075 visitors online*
    Doosan/FANUC 0i-M AICC
    Hi all,
    I'm not sure if this is the best forum, or if I should have posted this in the Doosan specific forum, butttttt.
    I have a brand new Doosan DNM4500 with the 0i-M Control.
    I'm currently working on implementing the AICC settings into my programs. When I add a G05.1 Q 1 Rx value, my AICC on the control always shows AICC 2. Does anyone know if this is correct (aka always shows this), or if something isn't positing correctly?
    I'm sure I'll have to call Doosan and ask, but didn't know if this is a common thing or if someone has any suggestions before I go down the rabbit hole of my distributor.
    Thanks in advance.
    Mitchell Parker
    Parker Precision Molding, Inc.
    Apr 2017
    18
    Re: Doosan/FANUC 0i-M AICC
    This is correct . It always shows AICC 2 whatever Precision Level is set with the R Value.
  1. Fanuc 0i-MD - Faceted with AICC 2
    By popex in forum Fanuc
    Last Post: 07-10-2015, 10:44 AM
  2. AICC vs. AI APC
    By Leha_Blin in forum Fanuc
    Last Post: 06-06-2010, 09:14 AM
  3. Fanuc 21i-mb AICC settings
    By contour in forum Fanuc
    Last Post: 01-21-2009, 08:58 AM
  4. Aicc/hpcc Vs Hsm (non Fanuc)
    By highspeedmike in forum Hard / High Speed Machining
    Last Post: 08-24-2007, 01:49 AM
  5. AICC HPCC Help
    By figeacaero in forum Hard / High Speed Machining
    Last Post: 06-15-2007, 07:22 AM
