485,517 reg. members
Results 1 to 5 of 5
    Dec 2005
    49
    DOOSAN PUMA 240 UL CERTIFICATION
    MACHINE : DOOSAN PUMA 240 2013
    Does any know if this machine is compliant with UL
    I need to make a UL certification on this machine , does any body went true the certification on this machine , what was your experience ?
    does the machine is full compliant or you have to replace parts ? , if you do approximate how much was the repair .
    i am trying to find out before do the labeling if it is not a crazy amount to make it compliant , i here of other machines brand that brand new has to spend $15000 to make them compliant
    of course the company take care of that but in my case the machine is not new
    thanks
    Daniel
    Feb 2013
    509
    Re: DOOSAN PUMA 240 UL CERTIFICATION
    Check on the Placard.
    They should show if CSA, UL, ETA certs.
    EXAMPLE shown: attached
    Doosan Service Technician - New Jersey Office
    Gold Member
    Feb 2009
    5921
    Find out as stated, but check if it HAS to be UL, or any NRTL cert. Most places allow the ETL, TUV etc. UL is by far the most expensive to have field certified.
    Sent from my SM-T813 using Tapatalk
    Dec 2005
    49
    NO the plate does not have the NRTL logo on it , i may believe they start after 2013
    Dec 2005
    49
  1. Buying a used doosan puma 480, puma 800l
    By Michael82 in forum Daewoo/Doosan
    Last Post: 09-05-2015, 01:44 PM
  2. Need help with my doosan puma 400 m
    By gongo999 in forum Daewoo/Doosan
    Last Post: 12-06-2014, 02:15 PM
  3. Help with doosan puma 300 lb
    By mattlynx in forum Daewoo/Doosan
    Last Post: 12-04-2013, 09:56 PM
  4. Doosan Puma 2100LY
    By D3abL3 in forum Daewoo/Doosan
    Last Post: 05-19-2012, 12:56 AM
