525,809 active members*
2,943 visitors online*
Results 1 to 10 of 10
    Apr 2008
    23
    Doosan tt1800sy
    I wondering if there is a parameter that can make
    The machine ignore wait codes when you are running only one side
    Nov 2007
    185
    Can you put a \ in front of your wait code then turn on block skip?
    Apr 2008
    23
    yes that works but I am afraid that someone will forget to turn it off
    when they go back to multi
    we have a nakamura wt100 and it just skips over wait code when running one
    side
    Gold Member
    Mar 2003
    2928
    Yes. I believe it's keep relay 0 bit 7 (not parameter), but don't quote me. Look in the blue binder in the electrical cabinet. There's a section in the back half that details the keep relays.
    Apr 2008
    23
    thanks I will check next week when I go back to work.
    I will post how I make out
    Jun 2007
    84
    In my book it is listed as K0.0
    Apr 2008
    23
    Thanks that works
    Keep relay k0.0 change from 0 to 1
    TT 1800 SY
    Fanuc 18i -tb
    Gold Member
    Mar 2003
    2928
    Quote Originally Posted by Don18P View Post
    I knew it was one end of K0 or the other. I don't have a book, and my memory isn't what it once was.
    Apr 2008
    23
    I couldn't find in the book but tried it and it worked thanks all
    Jun 2006
    364
    Re: Doosan tt1800sy
    Technically that's pretty dangerous if your program has crossovers, you could send a tool into a hole the lower was supposed to drill if it ignored wait codes.
  1. DOOSAN TT1800SY - TORQUE CONTROL ISSUES
    By MMSERV in forum Daewoo/Doosan
    Last Post: 04-09-2019, 12:26 PM
  2. TT1800SY maintenance
    By Don18P in forum Daewoo/Doosan
    Last Post: 09-25-2013, 04:52 PM
  3. TT1800SY HEADSTOCK REALIGNMENT
    Last Post: 01-10-2013, 06:49 PM
  4. TT1800SY Alarm 9015
    Last Post: 01-09-2013, 05:13 PM
  5. Replies: 11
    Last Post: 05-20-2012, 05:31 PM
