Re: drag engraver diamond vs carbide
I bought a spring loaded drag engraver many years ago and tried it with diamond tip engravers. After breaking the diamond off of them I got frustrated and just started making my own drag engravers out of broken and worn out 1/8 shank carbide endmills. I'd just chuck them in the drill and spin them against a grinder. Worked pretty good. I made several sharp pointed tips that way. They worked on all kinds of things, and I didn't break them like I did the diamond tipped ones. Aluminum, brass, even the side of a hard impact socket. I also made one rounded one I used for "embossing" a plastic wood grain covered soft wood box.
One thing I should mentioned is that drag engraving with a sharp tipped tool does raise a burr on aluminum and brass. More recently I rotary engraved brass plates by making a fixture/jig for them out of a piece of aluminum and clamping them down along the edges with button head screws. This way they are held flat and they can be rotary engraved more consistently. It does not seem to leave a burr the way drag engraving does. You can see tiny tool marks when cut dry, but when cut with flood coolant it looks very very good.
Bob La Londe
http://www.YumaBassMan.com
