594,859 active members*
5,627 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Drawing input coming from autocad
    I just started learning Alpha and one thing (among many) is doing my head in - i cant seem to find the function to draw/enter data in relative coords.
    Looked at manuals, watched videos/tutorials - everybody starts to draw examples at 0,0 ABS, which is all good and well.
    But what do i do if i want to draw a, say, rectangle from random picked point and is 20x10 size ? I dont know the coords of first picked point.
    Disregard all the snapping functions for now, how do i enter data RELATIVE to start point ?
    Do i make sense ?
    I come from autocad, which i use for decades by now(started on R10 on dos ), and all i might need to do there to switch to relative is to just add @ to entered data string (i draw/modify almost completely in CLI). For the life of me i cannot figure out how to do this in Alphacam... Embarrasing.
    Also, when it comes to snapping is there a reference snapping in Alpha ? Assumed extension lines from indicated snap points or something similar to autocad ?
    Re: Drawing input coming from autocad
    Quote Originally Posted by pointysticks View Post
    Do i make sense ?
    In Alphacam, you do not need to type an @ symbol to specify relative coordinates. Instead, simply enter the offset from your starting point (e.g., 20,10).
    That is exactly the problem, if i enter 20,10 the end point ends up at 20,10 ABS, not REL to start point.
  1. Need an AutoCAD drawing or custom Artwork?
    By JeremiahG in forum Waterjet General Topics
    Last Post: 08-25-2012, 09:05 PM
  2. I'm not sure where the problem is coming from autocad or sheetcam
    By jmschamness in forum Waterjet General Topics
    Last Post: 04-04-2011, 03:39 PM
  3. With AutoCad Drawing.
    By Stampede in forum BobCad-Cam
    Last Post: 02-18-2009, 07:45 AM
  4. How too, AutoCad drawing to BMP/JPEG
    By Holmes_ca in forum Autodesk
    Last Post: 02-17-2009, 04:05 PM
  5. autocad 2d/3d drawing/render into partmaster?
    By BulleTxMagneT in forum Dolphin CAD/CAM
    Last Post: 01-28-2008, 03:39 PM
