Originally Posted by
QuinnSjoblom
Wasn't really sure where to put this, it can be moved if needed.
I'm pretty happy with my home built machine the way it is, I can mill parts from 7075 with excellent accuracy(.01mm) but there's a couple limitations I've been trying to think of a way to get around. I've already posted about trying to get consistent tool length when changing tools in my er20. Few options there but either expensive, not that accurate, or not that fast. The other limitation I have is rpm. 6k minimum is a pretty big limiter. Also the er20 itself. I would really like to be able to use larger drills, boring heads, and face mills.
One solution I can think of is buying a drawbar type spindle cartridge and mount it next to my 2.2kw spindle on my z plate with a few belt drive options. Haven't done a ton of research yet, but tormach has a few options for around 500 bucks and they weigh about 20 pounds. No problem for my gantry to lug that around. Really wouldn't be hard to put it all together. I could make a few 1 inch thick plate mounts that hold both the spindle and cartridge side by side (2.2kw spindle upside down). I already have some experience milling htd pinions and pulleys so could come up with a pretty robust belt drive setup with some gearing options.
This could potentially address all the limitations I currently have. Faster tool changes, consistent tool offsets, all the rpm range I could ever want, bigger tool holding for facemills, boring heads, etc.
Has anyone tried putting a setup like this together? Any reason why it would be a bad idea? I don't plan on doing it soon, just something I'm looking into as a possibility.
