543,646 active members*
1,899 visitors online*
    Oct 2009
    47
    Dust Collection
    VF3, we are going to be cutting a type of Fiber Board that is messy and nasty. We will be recirculating our coolant and just cutting dry. Has any one used something similar to the attached image or is there a better solution out there?
    Attachment 462160
    This unit is much newer than our other units and am concerned about interference with the tool change.
    Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
    Jan 2012
    12
    Re: Dust Collection
    I'd be curious too. We cut foam and it is also messy. Right now we adapted the bar feeder panel to a duct that is attached to a large vacuum it helps, but could be better.
    In another application where we cut carbon, we use coolant for dust suppression and run it through a coffee filter roll before recycling the coolant.
  1. Dust collection :(
    By mykrowyre in forum DIY CNC Router Table Machines
    Last Post: 02-14-2018, 06:59 PM
  2. Dust collection : Dust deputy, clearvue min etc. - need some help
    By FoxCNC1 in forum Uncategorised WoodWorking Machines
    Last Post: 03-08-2015, 02:26 PM
  3. Sensing dust level in dust collection bin
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 04-07-2013, 10:26 PM
  4. Dust Collection
    By sonicwonder2000 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2010, 03:57 PM
  5. DUST COLLECTION
    By KustomKoncepts in forum Commercial CNC Wood Routers
    Last Post: 03-15-2008, 03:54 PM
