567,778 active members*
2,521 visitors online*
    Dyna Path Delta CNC system
    So I stumbled upon a guy selling a 1995 dynapath system on Craigslist. The CRT was non functioning but I can fix that.
    The motors looked brand new and seem to be big bucks to replace.
    They are Baldor MTE-4090-Special
    High voltage servo drives. I have the complete system. I was considering doing a retro fit with this system to use it with linux CNC or Mach 3/4
    is it worth is? Should I just sell it as parts to someone needing Dynapath stuff?
    Much of it looks like its in great condition and it came off a running machine.
    Is this worth anything? Is it worth my time?
    I even have all the manuals and such. Any thoughts? Thanks
    Aug 2011
    108
    Re: Dyna Path Delta CNC system
    Worth it/worth your time? Depends on your resources and skills, only you know about that.
    My observations:
    - Do you know what machine the control came from? Do you have access to full schematic diagram and features?
    - Your intended machine will have to match the original machine configuration reasonably closely.
    - Changing the PLC program will be a huge pain if you don't have access to the source code.
    - I don't see any spindle drive components (contactors, fuse block, etc).
    - The servo drives are analog +/- 10V, not compatible with Mach CNC software as far as I know. LinuxCNC can handle that though.
    - I don't see the 1 to 2 kW transformer to power the servo drives.
    The monitor has a standard VGA connection if you want to test the control.
    RT
    Jan 2023
    3
    hola, tienes informacion de como ajustar un servo amplificador sdfp1525-17 de los antiguos ( servo dynamics aw1450 . jun1993 )???
    Tengo un problema con un control dynapath delta 40m y necesito ajustar los servoamplificadores de los ejes.
  1. Programming Tsugami 3 path system
    By pr_1792 in forum CNC Swiss Screw Machines
    Last Post: 05-04-2021, 05:44 PM
  2. I need a price on a Delta 20 system
    By strantor in forum Dynapath
    Last Post: 11-01-2017, 06:57 PM
  3. DYNA EM3116 CNC Knee Mill system parameters needed
    By Hytek in forum Knee Vertical Mills
    Last Post: 08-16-2015, 02:17 AM
  4. Dyna path delta 20 to Linux CNC
    By JAKEFREESE in forum LinuxCNC (formerly EMC2)
    Last Post: 11-19-2014, 06:19 PM
  5. Dyna Path Machine center
    By salhab in forum Uncategorised MetalWorking Machines
    Last Post: 04-23-2008, 07:19 PM
