I can't find the info icon on setup after switch to manufacturing mode, although it was found in Edgecam 2016 R2.
Any ideas
Any ideas
you dont have to "switch" like before.
select your machine by clicking "create sequence" then select the "machining" tab above that, select your tool and roll.
the tabs "setup-features-machining-NC code" are the toggles you are thinking of and they are more fluid now instead of on/off like it use to be
But cant you just open the old files and do programming?
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
