541,109 active members*
3,537 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Edit Coolant Post Process for Haas
    I am trying to edit post process to turn coolant on after the first G0 and Z move for every tool. How should the code look to make that happen? Fusion 360 software on a Haas VF4.
    Thank you
    Oct 2011
    6
    Re: Edit Coolant Post Process for Haas
    I did this when I first started using fusion.
    Jan 2005
    12204
    Quote Originally Posted by Antvillareal View Post
    Thank you
    Depending on your Haas machine it already turns on with a tool change, this may not turn on when you want it so yes you can add it in to your code where you need it to turn on, normally it is not needed though
    Mactec54
  1. Need Haas vf1 post process
    By chitpon in forum Uncategorised CAM Discussion
    Last Post: 10-11-2017, 10:29 AM
  2. How to do I edit the post process in Fusion 360
    By jspmfg in forum Tormach Personal CNC Mill
    Last Post: 10-23-2016, 09:18 PM
  3. Need Haas vf1 post process
    Last Post: 09-29-2014, 06:59 AM
  4. Need to edit Haas post
    By Shotout in forum Post Processors for MC
    Last Post: 12-07-2007, 06:35 PM
  5. Edit Haas VF Post
    By trangt143 in forum Post Processors for MC
    Last Post: 11-22-2005, 03:55 PM
