562,563 active members*
3,939 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Electro craft E723 documentation and driver, how to run?
Results 1 to 7 of 7
    Dec 2020
    7
    Hi
    I want to run servomotor. Just some forward and reverese movements.
    Electro-craft E723 0723 32 018.
    I can't find any specifiaction
    What are the parameters?
    What driver to use?
    Maybe easier will be to install some new motor, but I don't know main parameters - torque, speed.
    Regards
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    24031
    Re: Electro craft E723 documentation and driver, how to run?
    What I have is 25.4 lb/in Stall torque, Pk torque 125lb/in, max term voltage 107vdc, 3000rpm max, some have a tach, which is not used in current systems.
    Albert E.
    Dec 2020
    7
    Thank you.
    What popular driver can I use for mentioned motor?
    Regards
    Dec 2003
    24031
    What do you intend to control the motor with, Manually? or with some kind of simple program?
    There is the A-M-C and similar servo controllers that can move the motor with an analogue signal or a pot etc.
    Albert E.
    Dec 2020
    7
    Hi
    I need some manual control. Forward, backward, speed control by the potentiometer or simple analog signal.
    Regards
    Dec 2003
    24031
    As mentioned, I usually pick up a DC servo drive, A-M-C etc drive off ebay
    Albert E.
    Dec 2020
    7
    I'm don't know which one can be proper for this motor.
  1. Electro Craft E670
    By pepemi in forum Servo Motors / Drives
    Last Post: 10-04-2012, 07:46 AM
  2. Electro Craft Drive
    By nnpepe in forum Want To Buy...Need help!
    Last Post: 05-14-2010, 10:53 PM
  3. Electro-craft servo Please help
    By j186281 in forum Servo Motors / Drives
    Last Post: 06-15-2008, 04:38 PM
  4. electro-craft motors
    By KPyro in forum Servo Motors / Drives
    Last Post: 08-31-2006, 09:15 AM
  5. Electro-Craft Motors
    By bill south in forum Servo Motors / Drives
    Last Post: 06-16-2005, 02:14 AM
