585,722 active members*
4,186 visitors online*
Results 1 to 4 of 4
    EMERGENCY HELP
    Biggest order of my life due in 3 weeks. Machine is at a stand still.
    My BOSS LASER machine will not fire. I am NOT technologically inclined, more creative. So I struggle with this. Boss Laser support is not open till Tuesday and I can't be down that long. Can ANYONE help me??
    Jun 2018
    362
    Re: EMERGENCY HELP
    The laser won't fire or the machine won't start?
    Does/can you move the cutting head manually?
    Sorry, not familiar with them but with most machines, do some basic troubleshooting like:
    0. The machine of course has power (sorry for asking but you'd be amazed)!
    1. Any error messages on screen or control panels, error indicators, check them against the operator/technical manual
    2. Any fault indicators on electronics modules (see item 1)
    3. Check fuses, circuit breakers and replace any blown fuses and/or reset breakers
    4. The machine of course was working, anything changed - find out and undo if that could be a cause
    If it's CO2 based, has it got gas?
    Nov 2010
    787
    Re: EMERGENCY HELP
    Quote Originally Posted by he1957 View Post
    Buhahaha :-D :-D
    CNC lasers, constructions, service
    Sep 2005
    1740
    Re: EMERGENCY HELP
    Check the simple stuff first, power does the machine move and not firing does it have a water flow switch or perhaps a door switch is not working.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  1. Emergency Stop
    By K2Developmentab in forum Fadal
    Last Post: 08-21-2013, 01:21 PM
  2. EMG EMERGENCY EXIN
    By chuy_pm in forum CNC Tooling
    Last Post: 12-06-2011, 08:18 PM
  3. another CNC emergency!!
    By kbillan in forum Taig Mills / Lathes
    Last Post: 06-11-2009, 05:15 PM
  4. Emergency stop
    By Franky42j in forum Philips
    Last Post: 08-20-2008, 03:16 PM
