600,668 active members*
3,873 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Enable FTP file transfer in FANUC 32i model B
    Hello,
    I'm trying to enable FTP file transfering in a Tsugami B0326III (FANUC 32i model B), and although I did like it's specified in the manual, I must be missing something because I can ping the machine IP from my PC and vice versa, but when I attempt to connect from filezilla to the machine over FTP I always get "Connection attempt failed with "ECONNREFUSED - Connection refused by server".
    Attached are some pics of my machine configuration. In the machine FTP configurations I'm using the embedded port and I set the machine's IP and everything like it says in the manual. I set "I/O channel" to 9 for the machine to act as FTP server. Chatgpt says I should have some indication that FTP function is enabled and that I have to set the "parameter write" to 1 (check pictures) to be able to then somehow enable the FTP function in the machine, but I'm not familiar with cnc machines so I don't want to be messing around without being sure. Is there any option to enable FTP function hidden somewhere in the machine's menus?
    Dec 2009
    1024
    Re: Enable FTP file transfer in FANUC 32i model B
    Did you enabled the parameter 901 bit 1?
  1. FTP file transfer
    By limcheewang in forum Fanuc
    Last Post: 10-17-2019, 03:23 PM
  2. FANUC 32i-Model B(GLS 5T Amada Wasino)
    By fajarbhe in forum Fanuc
    Last Post: 02-19-2018, 01:33 PM
  3. Fanuc Series 32i-model A
    By kurikka in forum Community Club House
    Last Post: 10-31-2013, 07:58 AM
  4. Fanuc 32i Model B
    By sidswiss in forum Fanuc
    Last Post: 01-17-2013, 10:12 PM
  5. Fanuc FTP transfer password setting, 31i & 0iTD
    By Deco-Doctor in forum CNC Swiss Screw Machines
    Last Post: 08-15-2011, 01:45 PM
