EAAK Enhanced waterjet cutting machine EK3020N applications:
The cutting materials are not limited (such as stainless steel,carbon steel,copper,brass,aluminum and other metal,glass,stone,marble,granite,foam,ceramics,pla stics,composite materials.), waterjet cutting is currently the most applicable cutting method;
Specification of EAAK CNC waterjet cutter machineryas follows)
Metal cutting: 1 Decoration of stainless steel,aluminum.iron,brass and other metal cutting process. 2 Manufacture of machinery and equipment control cabinets such as food machinery,medical machinery,CNC machinery. 3 The metal parts cutting such as stainlesssteel flange,semi-finished,steel construction, non-ferrous metal and so on. Glass cutting: 1 Gas stove surfaces, range hood,disinfecting cabinet, TV, bathroom products. 2 Construction and decoration glass,automotive glass. Ceramic and stone cutting: 1 Ceramic cutting for decoration and construction. 2 Marble mosaic,granite mosaicmstone plate cutting.
Model EK3020N X Y axis Working size 3000mm*2000mm Z working height 150mm Cutting Pressure 420Mpa 37kw UHP pump Control accuracy 0.01mm Cutting accuracy 0.1-0.2mm Repositioning Accuracy 0.05mm Max cutting thickness 300mm(depends on materials) Max. moving speed 6000mm/min Power supply 380V 50Hz Environmental temperature -10-50°C Max flow rate 3.7L/min Max oil discharge 206L/min Max delivery capacity of oil pump 106L/min Control system Ncstudio (Shanghai) software IPC controller CAD/CAM software AutoCAD,ArtCAM Drive motor Japan Yaskawa servo drive motor
