Originally Posted by
bescorza
Hi there!
I have a 3 axis CNC6090 with a 2.2 kw spindle.
Recently, after a 5 hours strait operation, the spindle became to work as half energy and I immediately turn it off.
After that, every attempt to run the spindle, the VFD pannel notified the "ERROR 13".
With this situation, I looked after some youtube videos and try to find what was about. At the same time, I change some parameters in VFD and that was a big mistake.
So, I decide to contact the factory (ChinaCNCzone or SCOTLE TECHNOLOGY). They gave me the path to reset all the parameters and recover the originals parameters. In addition, they explain to me that the "error 13" was a bad connection on the splindle cable or plugs.
Well, checking the continuity, I found the problem. The cable no. 3 was interrupted.
Problem solved
But not! Now, my VFD is showing the "error 11". That means 2 options: Motor protection parameter P9-01 or Small frequency converter selection
Is there someone that knows this parameters?
HELP, PLEASE!
