592,217 active members*
3,954 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > error 368 (Z axis serial data error (INT))
    Jul 2024
    7
    hello I have a CNC milling machine with Fanuc-mate MB control, recently error 368 (Z axis serial data error (INT)) comes in it, which is always fix in this and sometimes error 368 (Y axis serial data error (INT)) and (X axis serial data error (INT)), which is related. Can anyone help?
    May 2024
    32
    Re: error 368 (Z axis serial data error (INT))
    Error 368 on a Fanuc control system, indicating "Serial Data Error (INT)" for the Z, Y, or X axis, typically points to communication problems between the control and the servo amplifier or motor encoder. I would suggest checking up the wiring.
    Jul 2024
    7
    I checked all the voltage and connection in the wires and the health of the cables and the servo motor and the power supply, but I did not get any results
  1. Replies: 0
    Last Post: 02-24-2023, 02:13 PM
  2. Replies: 0
    Last Post: 02-24-2023, 02:03 PM
  3. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  4. RoboDrill Fanuc 368 serial data error
    By pupetxls in forum Vertical Mill, Lathe Project Log
    Last Post: 05-21-2018, 02:37 PM
  5. 18i-T = 368 B AXIS: Serial data error (int)
    By padobranac in forum Fanuc
    Last Post: 03-16-2009, 12:04 PM
