I've had an issue on my Kogna Milltronics conversion where I get the error in the title, followed by a bunch of other errors after running for several hours. I saw that KMotion Version 5.3.8 has the following in the release notes.
"KMotionDLL
Fix major issue with compiling/downloading C programs to Kogna. Checking Kogna Firmware Version left a file open
causing Application unable to open any files after 512 Version Checks resulting in many errors. The file is now properly
closed after each Version check."
I've been assuming that the error was caused by some windows thing (power saving, etc) disconnecting from the Kogna, and hadn't yet found time to dig deep trying to figure it out. I've been working around it by restarting the machine every 3 hours. Is this error caused by the firmware version check issue? It would be nice to know if I could stop restarting the machine without waiting to see if the error reoccurs.
Thanks,
-Nate
