528,075 active members*
2,698 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > ESS Series 3.0Nm(425oz.in) Nema 24 Integrated Closed Loop Stepper Servo Motor 24-50VD
Results 1 to 1 of 1
    Aug 2020
    Hi
    First of all, Im new to this but trying to figure it all out by digging the net.
    Im planning to buy a mill to convert to CNC. I have looked at these servo motors and have a few questions, https://www.omc-stepperonline.com/st...c-1000cpr.html
    1. Do I need a closed loop stepper motor driver for this motor or is all that integrated in this motor?
    2. What controller board would work whit these closed loop servos regarding hooking up all the cables for feed back and alrms etc.
    Regards
    Mikael
    Mar 2003
    35095
    Re: ESS Series 3.0Nm(425oz.in) Nema 24 Integrated Closed Loop Stepper Servo Motor 24-
    1), Yes, and it needs to be the correct drive for that motor
    2) Feedback would only go back to the drive. What software do you plan on using?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
