586,005 active members*
5,181 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Estimating required force(s) for routing wood or aluminum
    Jul 2020
    36
    I'm designing/building a 36"x24" router and I'm looking at a 2-3kW spindle. (https://www.cnczone.com/forums/cnc-w...10132-cnc.html)
    I have been learning the equations for motor sizing and ball screw force. It looks like a 1605 ball screw with a 5mm pitch can put out 120kg of force with a 1.9Nm stepper. I'm assuming that's an ideal situation subject to loss of stepper torque at higher speeds. However, I have not been able to find information on the force required to mill aluminum at typical DIY router rates. I have to believe there are all sorts of factors that affect this. Is this something DIY CNC router builders typically dive into or do you simply upsize drive components to far exceed the cutting forces that may be expected? Can anyone provide "ball park" figures on typical forces or point me to a resource?
    Thank you,
    Jerry.
    Mar 2003
    35538
    Re: Estimating required force(s) for routing wood or aluminum
    I would use 50 lbs as the number, but it's unlikely that you'll see cutting forces even half that.
    You'd probably stall the spindle before then.
    FYI, 1605 ballscrews are a poor choice for a router, as they are just too slow. 1610 or 2010 would be much better.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Milling force-cutting Aluminum
    By ablacksmith in forum Mechanical Calculations/Engineering Design
    Last Post: 07-22-2018, 11:04 PM
  2. cutting speed and force required to cut 4140 with HSS
    By Aquatic in forum MetalWork Discussion
    Last Post: 08-19-2010, 12:53 AM
  3. wood routing
    By ferrous in forum Employment Opportunity
    Last Post: 04-17-2010, 01:28 AM
  4. calculating expected max cutting force required
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-02-2007, 12:19 AM
  5. 3d wood routing...
    By Clan in forum CNC Machining Centers
    Last Post: 09-06-2004, 10:34 PM
