592,217 active members*
4,413 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Estop not switching off ext1 outputs
    Dec 2006
    32
    I have Estop "Outputs Off" enabled.
    Activating Estop switches off the outputs from the main board but doesn't switch off any of the outputs on the Ext1 board.
    Is there a way to address this? Either by selecting which of the Ext1 outputs to be turned off by Estop, or all of the outputs together?
    Dec 2006
    32
    Re: Estop not switching off ext1 outputs
    Hi everyone...I guess it's not possible? Anyone have a solution?
    Mar 2017
    1371
    This can be done with expression scripts.
  1. No +5V to outputs?
    By Yastron in forum Servo Motors / Drives
    Last Post: 06-28-2019, 05:36 AM
  2. When an Estop isn't an Estop
    By sin_arms in forum Tormach Personal CNC Mill
    Last Post: 01-31-2017, 05:19 AM
  3. Need More Outputs
    By Atomic_Sheep in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2016, 10:54 AM
  4. Need More Outputs
    By Atomic_Sheep in forum DIY CNC Router Table Machines
    Last Post: 11-06-2016, 06:52 AM
  5. Replies: 14
    Last Post: 05-04-2015, 02:21 PM
