527,854 active members*
2,569 visitors online*
Results 1 to 4 of 4
    Sep 2006
    Excel 810 VMC Parameters Fanuc O-M
    The batteries died in our Fanuc O-M control wiping out all the parameters. The machine is an excel 810 VMC 1993. Does anyone have a the same year,make and model machine that we could get the parameters from?
    Need help ASAP!!!!
    Thanks,
    Pete
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    23446
    Oh..O There a lesson there for all those that have not backed up their parameters:drowning:
    Cost a few minutes to back up to disk, untold grief when you don't!!
    Al.
    Albert E.
    Aug 2017
    12
    Re: Excel 810 VMC Parameters Fanuc O-M
    Quote Originally Posted by pvougi View Post
    Need help ASAP!!!!
    Thanks,
    Pete
    HI
    you have the parameters ?, I have a problem with the same CNC Excel 810 Control Fanuc O-M, when updating the parameters in specific when entering parameter 905 sheds ALARM SYSTEM 910 RAM PARITY LOW, does anyone know which RAM module you need to replace,
    If you already have your Excel 810 parameters, you can give me a copy of parameter 900 to 921 please
    Hi All!
    To Confyone:
    Have you found a solution to this problem?
    We have exactly the same - when we set parameter 905 the control does not start and shows error 910 PARITY (LOW)
    I would highly appreciate any help.
  1. kiwa excel 510 parameters
    By gbsengineers in forum Fanuc
    Last Post: 03-03-2014, 12:55 AM
  2. Excel / Kiwa 510 VMC Fanuc 0M) ATC Problem
    By MotoDan in forum Fanuc
    Last Post: 01-25-2014, 07:18 AM
  3. Data from Fanuc to Excel over Ethernet
    By mr_electrician in forum Fanuc
    Last Post: 02-16-2012, 10:39 PM
  4. Excel Colt 510 with Fanuc OM problem
    By techscan in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2011, 01:41 PM
  5. Excel Colt 510 with Fanuc OM problem
    By techscan in forum Fanuc
    Last Post: 09-13-2011, 07:15 PM
