544,016 active members*
2,406 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Expanded Line of EMUGE-FRANKEN TiNox-Cut End Mills Ideal For Aerospace Machining
    Feb 2010
    77
    WEST BOYLSTON, MA U.S.A. (May 26, 2021) – Emuge Corp. today announced the expansion of its EMUGE-FRANKEN TiNox-Cut End Mills line, designed for high-performance machining of demanding materials such as Inconel/ nickel alloys, titanium and stainless steel found in aerospace and other challenging applications. Four TiNox-Cut End Mill series are now offered, including the new 5-Flute N, NF, Base, and Trochoidal tools.
    5-Flute TiNox-Cut N: This new coolant fed series features 5 flutes for high feed rates, a raised land that increases chip clearance, and is ALCR-coated. It is a high-performance tool designed for roughing and finishing, especially suitable for materials such as titanium and titanium alloys.
    TiNox-Cut NF: This high-performance series features a fine chip breaker design that reduces chip size while reducing cutting forces. The tool features a proprietary TiN/ TiALN coating in both coolant fed and solid designs and is ideal for semi-finishing difficult materials such as nickel alloys.
    TiNox-Cut Base: The Base design is a material specific style tool with a proprietary TiN/ TiALN coating for roughing and finishing and is ideal for stainless and acid-resistant steels.
    TiNox-Cut Trochoidal: Ideal for high metal removal rates, this tool series features a newly developed geometry, a proprietary TiN/ TiALN coating and a chip breaker edge, which combined, reduces stress and vibration when machining difficult materials such as titanium and stainless steel. All tools are coolant fed for maximum performance. Designed for trochoidal milling via the overlapping movement of circular paths, these tools can rough and finish mill over 30% faster than standard designs, while increasing tool life significantly.
    EMUGE-FRANKEN TiNox-Cut End Mills are made from premium ultra-fine micro grain solid carbide with a maximized transverse rupture strength for high impact applications, and produce impressive results compared to conventional end mills. Advanced PVD-applied multi-layered coatings withstand excessive heat and provide superb wear resistance for longer tool life, and tool geometry is designed to produce minimal vibration when machining tough materials.
    TiNox-Cut N, NF and Trochoidal End Mills are available in axial internal coolant-through capability for maximum chip evacuation and cooling ability. TiNox-Cut N and TiNox-Cut Trochoidal tools are available in both square-end and corner radius configurations. Weldon flat shank construction is available in both TiNox-Cut NF and TiNox-Cut Trochoidal tools, and is compatible with Emuge FPC Milling Chucks featuring an anti-pullout pin lock system. Overall, the expanded line includes tools that are available in inch sizes ranging from ¼? to 1? in diameter, and in stub, standard, long and extra-long lengths.
    For more information, please visit: TiNox-Cut | Emuge Corporation.
    About EMUGE-FRANKEN
    For over 100 years, the German company group EMUGE-FRANKEN has been one of the world’s leading manufacturers of precision tools for thread cutting, gaging, clamping, and milling. With 1,950 employees, EMUGE-FRANKEN offers an innovative product program with 40,000 in-stock items and a multiple of that with customer-specific tools. The product range focuses on applications in the automotive industry, power plants, aerospace industry and medical technology as well as general manufacturing. As a complete system supplier for the machining industry, EMUGE-FRANKEN has branch offices or sales partners in 52 countries.
    About EMUGE-FRANKEN USA
    EMUGE-FRANKEN USA (Emuge Corp.) is a wholly-owned subsidiary of the 1,950 employee German company EMUGE-Werk Richard Glimpel GmbH & Co. KG (Lauf, Germany). EMUGE-FRANKEN USA also offers end-user technical support through a network of in-the-field engineers and in-house product specialists, all with extensive tooling and application experience. Over 10,000 types of cutting tools and accessories are stocked in the company’s U.S. and Canadian Headquarters located in West Boylston, MA, U.S.A. The recently expanded 50,000+ sq. ft. facility includes a technology center with a machining and tooling demonstration showroom and classroom, tool manufacturing and coating, reconditioning, warehouse, sales, support and administrative offices. For more information on EMUGE-FRANKEN USA, call 800-323-3013, at 1800 Century Drive, West Boylston, MA 01583-2121, or visit (Taps | End Mills | Thread Mills | Thrillers | Holders | Emuge).
    Jun 2021
    11
    Re: Expanded Line of EMUGE-FRANKEN TiNox-Cut End Mills Ideal For Aerospace Machining
    With the help of this article, I can learn more things
  1. Replies: 0
    Last Post: 03-22-2021, 07:40 PM
  2. EMUGE LAUNCHES LINE OF HIGH-PERFORMANCE SOLID CARBIDE END MILLS.
    By Pam Laite in forum News Announcements
    Last Post: 12-09-2015, 06:12 PM
  3. Replies: 0
    Last Post: 12-17-2010, 04:18 PM
  4. New Emuge End Mills for Dental Prosthetics Mfg
    Last Post: 02-08-2010, 05:17 PM
